h.240 wrote:Where are you bleeding it from? The clutch slave cylinder or the damper box that is mounted to the frame rail? I tried to bleed mine from both the damper box and the slave cylinder, but it didn't work after 1.5 hours of trying. I finally took off the stupid useless damper box and ran the fliud line directly to the slave cylinder from the master cylinder. After that it bled within minutes.
i did it from both nipple, box and slave.i even did the master clyinder (hard line) because i bought a new one so you can say all 3.
my bro think its something worse but then im not too sure.
anyone else know whats up with this????
