MoldyOldy240 »
https://forums.nicoclub.com/moldyoldy240-u41784.html
Mon Apr 27, 2009 6:40 pm
I'll try to give all the information that I can; I've posted this before, but in the technical (I should have known better).CAR: 1991 240sxTransmission: ManualEngine: KA24DERecently replaced parts: placed a used s14 fuel pump in.o2 sensor replaced almost 2 years agoKnock sensor replaced 16 months ago
6 Days ago I noticed a problem with my car on the freeway:
at 3,000 RPM in 5th gear the car would fall flat on it's face; wouldn't go any faster, just burned a lot of fuel (or atleast smelt like it).
When I got onto city streets these were my findings:
at idle; it remains constant (800 RPM) but the car shakes (like a rolling shake)
4th gear, 4000 RPM; I hit the gas, very little acceleration happens; rpms do not climb as perusal
I pulled the codes and received:
14 Vehicle speed sensor circuit32 EGR function45 Injector leak
I've had the code 32 for a while with no problem. The tach has been dropping reading for 8 months now (so I believe thats the code 14 right there)
Then the code 45; last time I received this one I believe I just cleaned out the intake and it went away...? anyways
I reset the ECU and the troubles went away for a time, yesterday (5 days since ECU reset) the problem came back.
This morning I my car died while I had the clutch pressed in. An hour ago I cleared the codes, drove it around till it happened again and threw a code; after 10 minutes of driving it tried to die a couple of times. While on a straightaway the CEL came on:
Code 45
When the car is hot or cold the idle becomes erratic and starts to sputter. this continues for a minute or two and then it chokes itself out.
Tomorrow I am going to do a vacuum pressure test to see if it's any of the lines.
Any ideas?I really need help; I don't have much time to diagnose because I work 12X7 right now, so I only have 30 minutes to figure things out.
