'91 240sx FB... overdrive light light flashes 16 times when I start the car.
romanstypula
Car: 91 240SX & 02 Miata LS
'91 240sx FB... My overdrive light light flashes 16 times when I start the car. If I flip the ignition on and off about 45 times without driving, it clears, but after a short drive, it happens again. At the same time, another issue developed. My overdrive doesnt like to engage or disengage smoothly after the car warms up. Are these problems related? Can someone please please please help me?Thanks in advance!Roman
corn322
Car: 1993 240sx
yeah, it sounds like something is wrong with it, and it's throwing you a code.
I don't know anything about auto trannys though, so hopefully someone else can help you out.
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
my o/d light flashes too, but im pretty sure its unrelated :P
barcode
Car: 2003 350Z Track (totaled)
my O/d Off light flashes too, and every time it does it decide to flash, my auto wont shift untill it get to like 4500 or 5000 rpm, no matter how hard i push the gas. it really sucks and it destoying my gas milage.
ricebike
2002 Quest
2005 Altima
there's a self-diagnosis procedure that you do w/ the key on-engine off, press da o/d button, shift gears, turning key off, depress gas peddal, set o/d switch back on, then read the flashes
(10 of them will flash--the judgement flash will stay on longer)...
d/l & check the automatic transmission section of the FSM
