RamonetB »
https://forums.nicoclub.com/ramonetb-u29232.html
Fri May 19, 2006 4:32 am
I figured I'd add some detail to this process since I just did it the other weekend (though in reverse order, went from analog to digital).
Swapping a digital cluster with an analog one is rather simple, actually. If it's your first time, plan for about 2 to 4 hours of work (although if everything goes smoothly it can be done in 45 minutes).
Firstly, take a gander at these:
The first picture is that of your digital cluster. The small black box on the right, and it's cap on the left, is the actual HUD for the unit. The wire you see at the bottom is the sub wiring harness. This is what attaches your cluster to the main wiring harness in the car.
The second picture is the sub wiring harness for an analog cluster. Yes, these pictures are from ebay, a great resource for 240 parts.
In the bottom picture, you can see on the left hand side a black connector. This is the part that connects this wiring harness to the main wiring harness in the car. To get it out, you'll need small hands or a long thin flat-head to press the retaining clip in while you use another hard to pull on the connector and let it slip free. The part actually connects to the main wiring harness behind the dash in the center, but it CAN be reached (again, by one hand or a set of small hands) through the cluster window.
To get the cluster out, you'll have to remove the panel beneath the steering column (5 screw / bolts, 10mm I believe -- you may have to remove the driver's side kick panel to get to one of the bolts. Not sure on your car), then remove the cluster facia (the thing with the defrots buttons, hazards, etc. You'll have to reach behind and unplug the connecting wires to this. Two screws at the top near the cluster itself hold it in as well.) To get the facia off, you may have to loosen two bolts beneath the steering column that hold the column in place. Kind of a tight fit getting it out.
Then you inscrew four screws that hold the cluster in. Then, unplug the sub wiring harness, plug the analog one in. Don't forget to swap odometers. This is pretty easy too, as they both use the same component. Pop the clear plate off the cluster, unscrew the components from the rear white side, pop the white side off, pull the speedometer and odometer out, swap and put them back together.
Assembly is reverse procedure. Although... as I recall, the motor that drives the odometer has a different connector from analog to digital. That's two screws on the odometer itself to remove. Another easy thing.
So mostly, it's just a lot of screws.
Hope that helps you.
I figured I'd post a quick one since I've never found the procedure in any of the searches I've done on the site.
Peace!
-kirk
