NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Nov 01, 2005 3:52 am
interlock relay [relay your talking about] gets its power on both sides from the same source, the ignition switch. then the other 2 lines go as follows. one goes to your starter and the other goes to the clutch switch and then to ground. obviously since you can jump the circuit to the starter you know 3 of the 4 lines are ok. so that leaves the one circuit going to the clutch switch. go down there and jump the switch with a paper clip or some sort of jumper, unplug it and jump the connector. if it starts you got a bad clutch switch. if not jumper the brown with white wire in the connector to a good body ground. If it starts now you have an open circuit in the ground side of the switch circuit. If it still doesnt start you have an open between the clutch switch and the interlock relay terminal with the brown and white wire. Use an ohm meter to check continuity from the relay to the clutch switch.
This is all based on the fact you jumped the power in the relay connector to the starter circuit in the relay connector.
