SemperWrenchin240SX »
https://forums.nicoclub.com/semperwrenchin240sx-u190435.html
Sat Jan 07, 2012 7:41 pm
1991 240sx KA24DE with auto trans. The only problem is that it wont move in any gear
Everything worked well until I hit a rough spot in the road while turning at an intersection back in November. No knocking, no popping, metal grinding, jerking, chugging...nothing unusal. It just stopped moving. So I pulled over, inspected underneath the car and didnt find any leaks or nothing broke. I tried to start back up and it started just fine. I moved the selector lever from Park to Drive and I got nothing. Tried 1, 2, and even Reverse...the car didnt move an inch. I revved it up and still nothing. After getting it towed home I pulled the transmission pan and replaced the filter and fluid, still nothing. The engine runs great and strong, it revs when I press the pedal and holds idle around 700-750 RPMS.
I have ran EVERY diagnostic test in the Chilton, FSM, online reseach, etc and all electrical systems check out within the specs. All voltage, ohms, etc are all reading as they should per the fsm's and chilton. All sensors are good and none of the wires are frayed, cut or broken. The transmission fluid and filter are both good, hell they were replaced when I first purchased the car in August when it had 209K on it. The cherry juice smells as it should and the magnet was ok. The flywheel is solid, no cracks, or breaks and its straight.
I just pulled the transmission tonight after finally having time to work on it. The transmission looks good and I pulled the torque converter off thinking that it may be the one-way clutch. After inspecting the torque converter, the one-way clutch is good and the sample fluid I pulled from it looks good.
I am at a loss for words and have absolutley no freakin clue what can cause my auto to just quit after traveling over a rough spot in the road.
As much as I would love to drop a 5 speed in, I cannot. I dont have the cash not time for the swap and this is also a car that my wife uses. So please no comments to drop a 5 speed in.
Has ANYONE ever encountered a situation like this? You're help would be greatly appreciated. Thank you all and Happy New Year!
Kenny
