91 240 understears when drifting
xero1
Car: 08 Altima Coupe
i heard that the 91-93 240 have a lot of understeer when drifting, i got a 91 240(180sx) and i was planning on learning to drift, and i am getting TEIN S-Tech lowering spring, am i going to have a lot of understearing. what can i do to minimize the under stearing?
kamikazestorm420
fat fat fat FAT rear sway bars and rear strut bars?
with no front sways or struts at all.
tryiian
Car: 95 blue emerald s14 KADE traded for 1992 black hatch base
a. practice: learnin things you can do that make the car not understeer... (which frankly, iThink, is ludicrous... you can slide too far and off th road maybe, but how does a car thats *fishtailing* have *understeer*?!)
b. Limited Slip Differential: clutch type, 2-way (for drifting)
c. practice *with* your new lsd
d. continue practicing
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
All S13's understeer to an extent (in stock form). Such is how our suspension is set up.
[Zero-S]
kamikazestorm420 wrote:fat fat fat FAT rear sway bars and rear strut bars?
No, no. You don't want too big of a rear sway, or you'll have your rear end going EVERYWHERE. 21mm sways should be big enough (*cough*hicas sways*cough*).
kamikazestorm420
Quote »No, no. You don't want too big of a rear sway, or you'll have your rear end going EVERYWHERE. 21mm sways should be big enough (*cough*hicas sways*cough*).[/quote]i was just kidding ...
93sleeper
Car: S13 project
Put really good tires on the front wheels and crappy tires on the back. The difference in grip levels will cause some incredible oversteer, I can attest to this.
