daotoad »
https://forums.nicoclub.com/daotoad-u33306.html
Sun Oct 09, 2005 1:36 pm
occasionally when starting the engine, it vibrates fairly violently for the first 30 - 90 seconds. I can get it to stop vibrating by racing the engine to about 2500 to 3500 rpms 2 or 3 times usually. I have new spark plugs, wires, distributor, rotor and cap, new 300zx fuel filter, stock replacement fuel pump, new O2 sensor, and the ECU says everything is OK. Most of the time I have noticed this problem on days when conditions were not the best, i.e., extreme temperatures, high humidity, or when the engine has not been ran for at least 2 or 3 days. Injector problems? If so, should I replace with stock injectors, or would larger ones help this situation? Thanks.
Also, I have an overheating issue. I searched for the solution, and I have not had much luck. My 240 will overheat fairly randomly, but usually it is when she sits for a while idling. I have replaced the radiator, the thermostat, the fan clutch, and the water temp sensor. I have flushed the cooling system, and I have repeatedly blead the system to try to get the air out. Should I just continue to try and get the rest of the air to bleed out of the sys. or is there something I am forgetting?
