mr_wizard »
https://forums.nicoclub.com/mr-wizard-u33966.html
Sat May 13, 2006 12:42 pm
Hmmmm, I still don't think your getting what I'm saying. The starter turns the motor over fine.... everything is getting juice. The starter is actually turning as it should at 400-500 RPM. The motor just wouldn't fire, like it wasn't getting any gas or something. ANYWAY, I figured out the problem... it was 1 or both of two things... the valve cover hose was severally cracked and the grounding wire on the alternator was loose. Both don't really make sense, since some people actually just put a littler filter on the valve cover breather... what would a little leak (causing better air flow) in the valve cover tubing do? Ah whatever. Now I have another problem, I can't rev passed 3300 RPM or it starts cutting out and throws me forward in my seat. Really weird. It runs fine up until then and then the motor runs like ****e. I messed with the timing a bit, that didn't do anything.
