'91 240 - leaking power steering fluid BAD
losthorizon
Car: '91 240SX SE Fastback
I have a '91 240sx SE Fastback. I've been driving it for about 7 years. In the past month, it has begun leaking power steering fluid so badly it goes through a bottle a week.
Any ideas where this leak could be coming from?? And is it a major expense to fix?
Thanks!
koukiKA240
Car: 1991 240sx KA-T
start by getting under the hood and cleaning everything, at least around the P/S resivior and pump. Im guessing u know where the res is. The pump is the top pully on the drivers side of the car. after cleaning it just watch for the leaks. If you're lucky it will just be a lose hose, or cracked hose. Good luck, hope i helped.~Sam
