91 240 idles rough, hesitates BADLY, kills itself and gets flooded easily
smokin240
My 240 has absolutely no torque anymore. It hesitates so bad I have to rev it to high RPM's to accelerate like "normal". Once it hits about 4100 RPM it doesn't jump anymore, instead it's smooth acceleration but the engine is loud as hell you can tell somethings not right because it still doesn't accelerate worth a damn. If the idle drops too fast it kills itself too. And if you give it too much gas while in gear it bogs down really bad. Today I came to a crossroads and let the RPM drop too fast and it killed itself. So I go to start it and it doesn't start. Long story short I flooded it and had to let it sit, unplug the fuel injectors, then start it, plug them back in... etc... and now I can't get it started back up after dieng me without flooding it. This has been going on for awhile and is driving me crazy. I don't have alot of cash to throw around to try and fix a bunch of things I think is wrong. So I'm sort of hoping for someone to pop up and say "Oh yeah, it's just the....". I'm also open to suggestions or ideas. I need to get this thing sold since I'm leaving for the military in a couple months, so it would be nice to have it running decent so I can get more than pocket change out of it. Thanks alot everyone. Here's my cardomain web page for ****s and giggles. http://www.cardomain.com/ride/2238486
I've replaced the MAFS, TPS, checked the plugs and grounding all trying to fix it as well, so it's not those. Thanks again.
Fifth ace
Have you checked all your injectors?
smokin240
Now it doesn't idle AT ALL. At first I was unplugging all the injectors and starting it up to get the excess gas out, then plugging them back in... now that doesn't work half the time either. I have to keep jumping out of the car in the middle of traffic to either push the car or try unplugging the injectors. So this time I just sat and waited then finally got it to start, and noticed it was running very hot, and even more sluggish. So at this point it's not even driveable, I can't keep jumping out of the car doing this in traffic. When it died coming out of my neighborhood since it won't idle, I unplugged 1 injector at a time and tried starting it and saw no difference. Although the engine did seem to try a little better to start with the #4 injector unplugged, it didn't start up.
