91 240 engine problem!!!!!!!!!
qstudent819
Car: 91 nissan 240sx
I've been having alot of overheating problems with my 240 and me being a dumb a*** i was stuck n a winter storm and had to drive it up a hill. as i was diving up the hill(in 1st gear the whole time)my temp meter started to rise until at the top of the hill it went past hot and jus cut off on me. when i tried to start it up it would make this whining noise but then wouldnt make any noise.....About 2 months later my battery was dead so i charged it up and after i connected everything i tried to start it up. when i turned the ignition the engine fan started to move and made a sound as if it wanted to start it......i dunno what the hell is wrong with my car. is the engine blown?? what should i do to get my car running again??
ghettoslide
Car: '90 240sx, '91 240sx, '98 DSM, '05 Avalance
normally if you do not punish it too bad you will warp the head or blow the gasket. Under sever circumstances you may have seized a piston. The heat inside the combustion chamber literally welded the piston to the block.
