The fan for my climate control is not working. I searched for this and found situations where people only had the high setting working or only had the bottom 3 settings working, but none of mine are working. The solution for the other problems was replacing a resister pack. Will that work for my problem and is a visual way to verify this? Also, where can I get this locally (need it soon for a trip) and any tips on replacing it? This is my first climate control problem.
The reason I'm not sure it is a resister problem is because I noticed the problem after a drift day and thought maybe something got jarred from going off the track onto the grass (no collision though). It seems this wouldn't cause a resister to blow. Any other ideas if its not the resisters?
Thanks for the responses.
-aesic
