squeefoo »
https://forums.nicoclub.com/squeefoo-u8899.html
Thu Nov 10, 2005 1:31 pm
My steering has been slightly stiff, thought I had it fixed when I put in a new brake switch. Better but not quite it. Then I took apart the pump and cleaned it out, it was clean anyway -but what the hell, you never know. I haven't driven it yet since I took the pump apart. I didn't want to start it (then shut it off) to see if the pressure switch closes or opens and test the ohms; since I don't even know what the specs should be!
It looks like there is a pressure switch in the high pressure side off the pump, the plug has two female connectors in it, as does the sensor, it screws into a bung directly on the pressure side hardline just ahead of the solenoid.
The real question is is there a test or specs anywhere for this thing? I can't find anything about it in the FSM ST section. No schematic -no wiring diagram ....ZIP !! My FSM is copyright 1989...could this be an oversight ?
I did manage to screw it into a hydraulic pump and ohm it at 1.3 @ 200 ohm
Any ideas or answers ? Thanks.
