cccpman »
https://forums.nicoclub.com/cccpman-u36612.html
Thu Jul 12, 2007 2:38 pm
I started on trying to restore my Q to new now that the military has decided to give me some backpay - alot of new rubber parts, fuel pump, tires, glass etc. Anyways now that im getting past some of the most important parts I need to address the sounds coming from the engine
I have a new under engine cover (old one is MIA causing the car to get a little bit hot) and I hope installing that sometime next week will help but its not going to solve whatever is causing the problem. Hard to describe but here it goes, its a repetitive sound, gets louder when the car is in neutral, and its almost like a pump or power steering or something sound. Im not a car person by any means (and apparently I cant describe sounds worth a damn) Ive heard reference to a bad fan clutch causing alot of noise, and also could contribute to the heat problem (operating temp in about 60-90 seconds - never really goes above but I know the gauges on the Q are not too accurate - and the blade spins more then it should, i know the clutch isnt good but is it the problem?)
Trying to decide on the next repair, the fan has a couple tiny cracks in it, so its on the list. Belts are very old, they are on the list too - but I really need to solve this problem sooner rather then later. It doesn't squeak like most cars do with crappy belts, the fan blades are not rubbing on the housing... I dont know its rather hopeless, Im not sure how but I need to figure out how to get a sound recording up to help diagnose this problem
Belts, Blades,Fan Clutch, PS Pump, ??? ideas or any questions to help diagnose this?
And if i may go off topic on my own topic - pop charger or high flow intake from infinitipartsusa.com (need to do even a little something since there isnt any info about the NICO ECU going around). Again im not a car person so I really dont know anything about a pop charger (is it just a high flow intake that gives the engine a different sound?)
Thanks ahead of time for any replies
