I got the 97.5 Q, got 93K now. I have put about 60K in 3 years.
History--------Had done proper 30K service with ATF flush done at 35K.
Proper 60K service with all fluid flushes etc done 1.5 yrs ago. Did pan/drop ATF flush at that time too. Belts, brakes replaced. Fuel filter replaced as well. The only repair done was replacing the leaking front tension rods.
Time to do the next service. 90K.Also, my 100K extended warranty expires this June 23rd. My transmission has a 10 second cold start whine which I brought up to this board, most mentioned this as normal.
What should I do for the 90K service?I wanted to do this in the dealership so that warranty repairs could happen easily.
90K service: 599.00 All 5 fluid flushes (ATF, PS, Brake Fluid, fuel rail & coolant): 499.00+ rear differential flush.
Anything missing? Something not required? Pointers and any help is greatly appreciated.thanks a lotPN
