You do know that you get the most efficient combustion with temps around 200* F, right? If you are below 180*, then your ECU will revert to warm-up mode and your car will run rich.rico05 wrote:Koyo R1276 (2.1" dual core), 16 row B&M oil cooler, new thermostat, Nismo radiator cap, radiator panel, and Altima fans (one of the fans died, so I will be replacing next weekend with a Zirgo and a thermostat). So here is my issue: Even with only 1 fan running, I am still getting temps around 180*. Now, once it gets there, it pretty much stays there according to my aftermarket gauge. Now, my stock gauge will go to about 3/4 to H, and that worries me. I know that 180* is ok, but I just dropped a lot on this cooling system, and i was hoping that it would make a difference. But I guess it doesn't. Any feedback, or am I being worried for nothing?
Has nothing to do with a standalone...or tuning. It has to do with the heat energy being absorbed by the block and not used to force the pistons down.boost_boy wrote:My car runs between 146 and 176 degrees and it runs like a mean monster. When it's at 136 or lower, the power is just insane. Possibly because I tune around those temperatures, but then again, that's the beauty of a standalone.
Dee
Who said the operating temperatures of my engine had to do with a standalone and tuning. You guys read too much/too fast and seem to always miss the point. If you really paid attention to what I wrote, you guys would understand the point. I'll make it a bit simpler, I tune around the temperatures my car tend to reach which are between 136 and 176 degrees respectfully. I didn't say I tune my car with a standalone so it can run the temperatures I posted before.c-rad wrote:
I DID read it and all I was getting at is that if your car was running 190-200*F than it would make more use of the heat energy being created. I wasn't trying to give a lesson, but the way you made it seem is as if temps that low were a good thing (provided you have the use of a standalone ems).boost_boy wrote:Who said the operating temperatures of my engine had to do with a standalone and tuning. You guys read too much/too fast and seem to always miss the point. If you really paid attention to what I read, you guys would understand the point. I'll make it a bit simpler, I tune around the temperatures my car tend to reach which are between 136 and 176 degrees respectfully. I didn't say I tune my car with a standalone so it can run the temperatures I posted before.
There would be a few less CA18DET owners having problems if they'd slow down and read entire contents (hoping that they comprehend) instead trying to take short cuts and rely upon keywords. Not busting any balls, just stating the facts. And Chris, thanks for the 101 on energy and physics. I really needed that.................
Dee
I think over the course of time and dealing with me and the way I come across on certain topics, you of allpeople should know that I wouldn't preach about something that isn't good for my car because it sure as hell wouldn't be good for anyone else's. If I was preaching about how good a standalone is at helping with temperatures, I would probably say that if my car was to sit at 136 degrees, and I wanted my car to perform at an optimum level, I can trim the fuel parameters for that particular temperature and the same goes for air temperature and fuel adjustability for that parameter. I was actually being sarcastic about the 101 thing, but as knightrider says, some of this crap can be idiot-proofed if people read carefully and not fly through everything trying to seek the first word that corresponds to their issues. And believe it or not, I enjoy the cool running temperatures of my car. You RWD guys don't have the issues that my FWD car encounters. Because of the size of the turbo and placement of the radiator fans, the turbo's rear housing sits less than an inch from the 10inch cooling fan; almost always resulting in the death of the fan motor due to excessive heat. So with the turbo being that close to my radiator, I've experienced the overheating crap in the past years. Fortunately for me, those problems are a thing of the past, except for the radiator fan being under so much heat.c-rad wrote:
I recommend you RWD guys at least keep normal to mild performance operating engine temperatures around 180-200 degrees (preferably the 180) if possible. I do not recommend people attempting to run their cars at the temperatures I run mine because your car would just be a dog with the way the factory have those chips programmed. Do as I say and not as I do because I don't use a thermostat...................Kouks wrote:BOOST_Boy-So would you agree that for people with RWD CA's, 180-200 degrees is the optimum level at which to build around?
I can understand your point in that, you break less stuff in your particular set up with keeping the motor that cold, but the answer to overheating for most people isnt to change to the lowest degree thermostat.
To Rico, any ducting you can do to help get air to your radiator would greatly help, and slightly raising your hood for a positive pull which keeps underhood temperatures down while driving, can be very beneficial.
The only other upgrade you can do is to replace those altima fans with something that push more cfm.
I have the ducting (as stated in my first post) and I have a pretty sever (2") hood prop at the rear. And I just bought a 2700CFM 16" single Zirgo fan.Kouks wrote:To Rico, any ducting you can do to help get air to your radiator would greatly help, and slightly raising your hood for a positive pull which keeps underhood temperatures down while driving, can be very beneficial.
Oh i dont doubt youre a great mechanic, its just i was just giving a suggestion. Also sometimes we tend to overlook the obvious or the smaller things. Im thinking its going to be electrical because mechanically, there would be no danger with the components you said you were running. Maybe the temp switch is faulty and its giving incorrect readings?rico05 wrote:Trust me, I am a good enough mechainc that was the 1st thing that I checked.
Wait a minute... i must be missing something. So what ended up being your problem and fix? The fan?rico05 wrote:Oh, I totally beleive that now. I beat the hell outta my car on the highway yesterday in the heat of the day (~95*) and the temps stayed rock solid at 180*, even during 12psi runs. I am all good now. Thanks guys!!
Or could it be the sending unit like i said before? the gauge is just showing you what the sending unit is reading...rico05 wrote:No, I am 99% sure that either the sender for the cluster or the cluster itself if bad. My tacho is off by 300-500RPM (according to my ECU via my HKS E-01 turbo timer) so it is wholly probable that the temp gauge is off as well. I can boost all day long in the heat and never go above 185* according to my full sweep electric Autometer temp gauge.
