90 with abs brake problem
clss240
Car: 1990 240sx hatch
I cant seem to get any pedal stiffness at all
the brake will apply when the medal is almost at the floor. i've bled all 4 corners multiple times. the rears look good. but i cant get the fronts to bleed pure fluid. it always has air. i've bled them quite a bit. i have no visible holes or leaks in my lines. could my abs module be going bad? i have a parts car with non-abs should i just swap it all over? and ditch the abs? what all is involved in that? sorry for all thequestions and thanks for any help you may be able to provide me
s13gebala
Car: 99 Nissan Maxima
91 Nissan SR hatch
seems like the abs unit fked up
air can almost come from anywhere it should be an easy fix but if you cant fnd the reason i think its the abs unit, i took mine out and went no-abs now
