'90 Swapped - Please Help Me Plan Rest of Build
BlazedGlory
I recently picked up a 1990 240sx fastback with redtop already swapped in (couple of pictures: http://forums.thevboard.com/viewtopic.php?t=13508 ). Current known mods are as follows:
Greddy Type S BOVunknown custom FMICKoyo Aluminum Radiator w/ single electric fanLSDWahlbro 255lph fuel pump (pretty sure)Crappy TurboXS manual boost controllerSAFCIIApex'i N1 cat-backlarger throttle body
This car will be my daily driver, for I plan on selling my SpecV. My goal is to get approximately 350-400whp on 93 octane with a new turbo, injectors, engine management. Then perhaps later I will possibly add some simple bolt-ons like cams and whatnot.
Let me start by saying that I have searched and found some basic information, but I'm kind of having a hard time deciding exactly what is necessary without going overboard. I was initially considering getting a GT25R, but now I'm trying to look into some cheaper alternatives with similar performance (any suggestions?). I would like to be able to run the stock manifold if at all possible for cost reasons. The main problem I'm having right now is trying to decide exactly what kind of engine management to go for. I like running an atmospheric BOV, so I'd like to get something that can handle that - I assume I need something with a MAP sensor to bypass the MAF. Is that correct?
I think I read something somewhere that Apexi's AVC-R has a map sensor, but I'm not sure. I don't think Greddy's Emanage has one, and I've read that it isn't really all that great of a setup anyway. Apexi's PowerFC is a little more expensive, but I'd be willing to pay for it I think if it is necessary. I am not willing to pay a whole crapload for something like an AEM standalone though. I do not plan on tuning it myself, so no worries about that.
So basically my main question is about the engine management and some way to run an atmospheric BOV without a high idle and flames shooting out of the exhaust (I assume that is what is causing that in addition to the car running very rich perhaps right now? My theory is that the MAF is reading air and then when I let off the gas and it blows off then it makes the car run VERY rich for a split second, is this correct?). Keep in mind that I already have an SAFCII, so it could always be possible to run that in conjunction with something else if necessary (I assume?).
Or if you feel you must you can just tell me to quit being a dumbass and just recirculate .
Thanks in advance for your help...
