90 swap
Turb0wned
how much more trouble will it be if instead of getting a 91 240 and swaping my sr20 i have into it, getting a 90 240 and doing the swap on that one? i can get a 1990 240 right now for 1000k in pretty goo condition.... what should i do? the only thing i dont like about the 90 is the front bumper that pig nose...
Turb0wned
anyone.....???? at all i need to find out if i should buy it before it sells
TruboostPerformance
it does not matter all the 240 swaps go in the same, some just require some different wiring, no matter wheather you get a 91 or 90 that will be the same swap setup
S14Life
Car: b5 s4 stage 3, 2001 pathfinder, 91 s10
Exceptn on a 89-90 240SX you need the ps lines from a 91-94 model. Other than that exactly the same, and you can even swap the 91-94 front ednd onto an 89-90 if you had the time/money.
nissanrcer240
Car: 90 Nissan 240SX SR20DET
Also I think you're going to need a gauge cluster from a 91+ or the JDM gauge cluster
sil80S13
Car: showing off my n/a sohc ka. har har har
yeah on the 89-90 power steering lines are different, u can bend them to fit, but u will need a new ps resevoir. the wiring is slightly different. the gauges. ack those are a pain, its just the tach though. get the jdm cluster while its still cheap on ebay. the 89-90 are prone to a lil more rush. so becareful with some of the parts they wont come off too easy. be fure to buy lots of wd40 or a very good quality lube spray.
Turb0wned
thanks
