NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue May 02, 2006 3:14 pm
Its very tight but it slides out through the opening in the wheel well where the tie rod goes through. There are 4 or 5 17mm bolts holding it to the car. there is a 12mm bolt holding the input shaft to the coloum.[ need to pull boot up or down to get to it] there is a hard line need a 14mm line wrench to break it loose without stripping it. there is a hose with an 8 or 10mm head clamp screw. You have 2 19mm castle nuts that hold the outer tie rod to the spindle.
To remove the tie rods from the spindle. remove the cotter pin and castle nut. place a pry bar between the tie rod and spindle. while prying the tie rod hit the spindle where it surround the tie rod joint. this should jar it loose and it will pop out be preparred to catch your self or place the castle nut on by a couple threads. When removing the input shaft bolt make sure the steering wheel is straight ahead and the key is out of the ignition so it will lock the steering in place and not rotate. mark center on the rack.
For extraction you will slide it down off the coloum joint, move the rack toward the opening [prefferably the one on the passenger side] then you will need to angle and rotate the whole rack to get it to fit through the opening, this is the trickiest part of it. Be paitent and logical about your angles when moving it around.
The easy way to get it out is to remove the trans...lol. It practacly falls out with the trans out.
