90 sohc help. PLEASE HELP NISSAN TECHS!!
SCKA24E
Car: 90 240 sx M
i have a Manual 90 240sx w/ 145xxx miles ive replaced just about all the obviouse , spark plugs, o2, cleaned MAF, cap, rotor, plugs, coolent temp. snsor, oil sensor, tried to adjust timing,cleaned throttle body, changed pcv valve, and my car still runs real bad , it surges hesitates, accelerates slowly and lags at times i get about 16-18 mpg and ai have a pretty bad fuel smell, i tried changing 2 fuel injectors which seemed to be leaking and it helped a lil for about 2 days then just got worse. at idle my engine shakes pretty bad ( misses alot) and i had to turn my idle speed up because it started ideling at 550 rpms, i would really appreciate yur help as no one has been able to help me for 5 months now. if it helps latley when i turn my ac on the car barley runs, but this just recentley happened if been battling the other problem since i bought the car. PLEASE SOMEONE HELP!!..
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
When you installed the new injectors did you install new O-Rings..?? Sometimes they can leak when you dont use new O rings.....
have you cheked the resistance on them also?
NISTECH
Where did all your parts come from? new or used?Also have you tried to pull codes out of the ECM?
SCKA24E
Car: 90 240 sx M
all my parts were new besides the injectors and coolant temp sensor, my ecu gives a 55 - no error.
180fan
Car: 89 fastback
Smells like a MAFS issue to me. Wiggle the plug or try a different MAFS. A MAFS issue reamed me for 2 or 3 weeks before it was discovered and the ECU wasn't tellin me jack. Try that one if you've got nothin else to try
NISTECH
check your wiring to your maf for good ground, there are several threads in here covering that. try a search for MAF as well as coolant temp connector.
