carcrazyguy »
https://forums.nicoclub.com/carcrazyguy-u35889.html
Wed Dec 20, 2006 7:32 pm
My last 240 was a 90 with SOHC (of course).Anyway, initially it got really poor gas mileage (for a 4 cylinder). I would guess I was getting around 28 on the highway, and low 20's in town.Also, sometimes the car would idle really bumpy, and even when it didn't do that, the idle was not that great.One day I had the hood open and smelled fuel very strong. After poking around, I noticed a fuel leaking from an injector o-ring. I went ahead and put all new o-rings in but it still leaked at the same injector. So out of curiousity, I switched the leaking injector with the very front injector. Once I did that the front position was leaking - so I had isolated the problem as the injector. Out of curiousity, I pulled a the plug where the bad injector was and it looked to be very rich. I pulled another for comparison and it was night and day.What was occuring is that the injector was stuck all the way open, so even at idle and normal driving, one injector was operating as if the pedal was to the floor. Once the car was turned off, the injector was still open so any remaining fuel pressure would push its way out since it could not be burned. Since the day I bought the car I had noticed a fuel smell after the car was off, but always thought it was my imagination.Anyway, I priced injectors and they were relatively high - seems like about $75 each for remanufactured units. What I ended up doing is buying a used set of 4 injectors on Ebay for $20. I figured at least one of them would be good. I put one in place of the bad one, and fired the car up,Immediately, the car idled perfect...well, as perfect as the truck engine can. Also, once I drove it, the car was much smoother and had more torque at lower rpms - due to the fact that with the stuck injector, the o2 sensor was surely backing the fuel ratio off at anything less than full throttle because of the unburnt fuel. Anyway, I began to notice a HUGE improvement in fuel economy after that. At the time I was driving most highway, and taking it easy, but I remember averaging 35.X on the first tank I averaged after the repair.So this may not be your problem, but I do know for a fact that this is a common problem with these cars, particualrly with the SOHC, because they have so much immediate low end torque that many people drive them at 1/4 throttle or less most of the time. Then when they "kick it" every blue moon the dirty injectors can stick open. Hopefully this may help your problem.
