90 sohc engine rattle
N_E_R_V_EVA01
Car: Toyota MR2, girlfriends car Nissan 240sx
my girls 240sx is making a rattling sound on start up that is extremly loud and when i hit 2000-3000 rpm it also rattles its not a constant rattle but is a on off rattle sounds like its scraping on the cover or somthing. im just getting tired of hearing it and i want to fix it any idea how much for this type of repair. i have the tools to do almost anything.
ka24depower
Car: 1990 nissan 240sx
have you listened to see were the rattle is coming from.Is it coming from the front or the rear of the engine.
Import_Ant
check all of your heatshields on the exhaust. mabey one of the bolts came loose?
gumby
Car: '89 240sx sohc
well whatever you do make sure its not the timing chain cause if it cuts through the timing cover or snaps the car is sunk
jaredt
Car: 92 nissan 240sx fastback
i had the same problem it was a heat shield, the smaller one near the bottom of the exaust manifold, it is hard to get to but i just bent mine back with vise grips and never heard from it again.
N_E_R_V_EVA01
well its not the heat shield on the exhaust manifold; i tryed tighting it down and all the bolts broke, so i just took it off and the rattle is comming from the front of the engine. but i havent cheaked the ones on the bottom
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
WHat about the TIMEING chain.
