180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon May 22, 2006 1:24 pm
I've heard of the stanza's ecu doing the job but not the maxima.
the cutting of wires to get around the speed limiter I've heard mixed things about as well. Especially considering that there are quite a few auto ka ecu's floating around you just gotta look and wait for it to come around. I'd recommend the auto ecu vs chop job for the same reason there's a negative connotation associated with the phrase "chop job." It can make a mess with wiring and also cause weirder problems down the road. I have however heard of people adding switches to the transmission wiring to bypass the speed limiter when they want it on and would probably say go with that method vs just flat out cutting the wiring and just leaving it cut.
