ahardb0dy »
https://forums.nicoclub.com/ahardb0dy-u30854.html
Tue Nov 24, 2009 6:18 pm
Hello all, hope someone can help with this cause I have no idea where this noise is coming from !!
90 Nissan sentra, 212 K miles, originally had a 4 speed now has a new 5 speed transmission right out of the Nissan crate, 5 speed was installed at 183K 06-2007 using Amsoil gear lube, noticed noise yesterday on way home from work, I'll be driving along, speed doesn't matter although I haven't heard this noise when not driving, all of a sudden with no warning I started to hear this really loud noise, sounded like I was dragging something metal under the car, sounds like it's coming from the engine area and I also noticed when I hear the noise I can feel it thru the shifter. Got home from work and checked under the car with flashlight, exhaust looks normal, nothing hanging, checked under hood everything looks normal, nothing loose. This noise is quiet some times than other times it sounds really loud, thought oil was low so I checked it this morning on the way to work, it was a little low, topped it off but didn't help with noise. Have decent oil pressure on Autometer mechanical gauge, water temp is normal on Autometer mechanical gauge also. Checked oil level in transmission and it is full, timing chain and guides are original as far as I know, I bought the car with 117 K on it. Car runs great and when I hear this noise and can feel it thru the shifter it doesn't effect how it is running or driving. Could noise be from worn timing chain or guides?? mechanic said it may be the input bushing, checked my records and this was not replaced, he also said if I step on the clutch and the noise stops it most likely is the input bushing. Today when I got home with car in neutral it started making this noise almost sounds like nuts in the engine. Anyone ever have a noise like this any ideas on what it could be or what I should check?? Thanks all
