AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Tue Nov 29, 2005 4:30 pm
Remove the harness from the injector (Squeeze underside of clip and it should pull right off).
Remove 2 screws and cap.
Injector can be grasped with a pair of channel lock pliers and GENTLY turned rotated while pulling. Should pop right out.
Use a dental pick or other small object to remove both O-rings and replace.
Coat both o-rings liberally with vaseline.
Rinsert injector. You'll have to press VERY formly to get it to pop in place, but you can't wiggle it - Has to be straight in.
I use an 8mm socket on a ratchet, then you can press it in with the heel of your hand, or give it a good whack with the side of your fist...
Replace screws and harness and roll.
