golgo13 »
https://forums.nicoclub.com/golgo13-u39974.html
Thu Jun 29, 2006 8:03 am
Update: Put the fuel pump (last pic) on and connected the fuel line. I put a newer fuel line with 3/8 ID which seemed a little looser than the previous one, so I just tighted the clamps as much as possible.
Update: I took out the pump and tried to improve the connections as suggested. My soldering skills are horrible as is my crappy iron so let me know what you think. I did a crimp/solder deal on the disconnects and put a new jacket and little heatshrink tube on the ends which I haven't sealed yet. Images are in this post replacing older ones (pics 2.0)
Orginal Post:
First off, I'm a novice. NEWBIE ALERT~~ Ok, got that out of the way...
At this moment, I'm doing a fuel pump replacement. I'm replacing the old pump with a new OEM pump. So far, I've removed the old pump and I'm connecting the +/- terminals to the factory blade terminals. The old pump appears not to have been factory and I had to remove the splice and put M terminals. Can you folks take a look at my connection and give me a progress report. I'm not entirely comfortable with the connectors being so bare like they are but I'm a novice, so what do i Know?
It's raining outside so It appears I won't be able to put this back in today. So, if you can take a look and give me any advice or suggestions I'd appreciate it.
Pics 2.0
Modified by golgo13 at 8:22 AM 7/3/2006
Modified by golgo13 at 8:35 AM 7/3/2006
Modified by golgo13 at 8:40 AM 7/3/2006
