90 rps13 let me pick ur brains....
bades
Alrighty guys Im on vacation 7 hours from my home.... needless to say I didnt bring alot of my tools...Ive been searching for the answer but havent been able to figure it out so Im askin you guys....
ok heres the deal, i have an rb swapped rps13. I have a huge pull from sumwhere. narrowed it down.
I have found that when ever i pull the window fuse labeled ENG CONT (FL25A) in the passenger side of the engine bay (chasis panel)the pull goes away. So sumthing attached to that fuse is shorting out.
So heres my question..... What is attached to this fuse??? What does it control??? And is it needed for safe operation???? Any help would be greatly appreciated.... thnx n advance fellas....
Bongpain
Car: 92 240sx
well i cant seem to locate the fla25a fuse. is it a clear 25a fuse that is for eng con or window? but look at this to see if you see anything.
Roger_cha
Car: 91 nissan 240sx
well i have that problem once but give more info... does the brake light comes on even if you didnt pull the e-brake or somthing like that... it the one that you talking about is the engine cont fuse and not the relay then looks like it might be one of your circuit breaker relay, but im not sure check it out n see.
