Elwesso - Maniz - Skibane
I'm honored that all three of you, really involved NICO members, responded to my dilemna so quickly. This week was mid-term exams, so I haven't had much time to reply. A few more details about the problems may help.
The car was inoperable for quite a while while I tried to figure out what blew out my headlights, radio head unit, and boiled over a brand new closed-cell, gel-type battery. Turns out that the rebuilt alternator I sourced from a local auto parts store wasn't functioning properly, AND I had a grounding problem. Fixed the grounds and installed a rebuilt alternator from Infiniti of Scottsdale, traded out the headlights and radio unit for some used ones, and everything was A-OK. During the process I found a loose connection at the fuel pump controller unit, fixed it, and the car has never run stronger. While I was at it, I replaced all of the belts. So, I decided to put some more time and money into it.
I next installed new front upper suspension links, new front rotors and related brake pads sourced from Stillen, and broke them in over the next 100 miles. The car was running so well that I decided to 'bite the bullet' and convert the AirCon system before my very noisy compressor gave out, so I took it to the local Community College for the work. Well, it didn't, work out that is, so I got the car back with no charge except for the conversion kit and rebuilt compressor ($$$), and drove it home - about 10 miles. That is when I noticed all of the problems I listed in my original post. Everything was working before, so your suggestions probably won't have any effect, because it all happened at the same time.
I have tried a couple of things. I swapped out the combined HICAS/power steering control unit and also the relay above the steering column under the dash with used items, but to no avail. I also noticed that the 120 amp main fuse looked corroded, so I replaced it with a new Nissan unit, but nothing changed. I even pulled the instrument panel and replaced the fuel gauge with a used one, but of course it didn't work either.
I can't think of anything the college students might have done to cause the problem, but they did have the car for 6 weeks. I really think that I may not have fixed all of the grounding problems and maybe that is the problem. I love this car, and have always maintained it to NICO standards, so I'm at a loss. Is there a chqance that any one electrical component could be at fault?
Again, I appreciate your input ............... John
