90 q45 to 94 q45 crank angle sensor
Scorpius01
Car: 90 Infiniti Q45
Already searched, no legit solutions documented other than contact me.
The dilemma, have a 90q45 and aquired a 94-96 vh45de. The 90 has 2 into 3 wires for a sub cam sensor that the 94-96 does not. For someone that has been there what wire does the sub cam sensor signal get attached to on the crank angle sensor 4 terminal connector in addition to changing the 4 terminal connector?
If I don’t get an answer I will just use the s1 timing covers, valve covers so I can use the s1 crank angle sensor. Just wanted actual valve cover gaskets instead of FIPG.
I have access to the FSM on this forum but could be better to navigate.
Scorpius01
Got the info I needed by finding a 95-96 wiring diagram in addition to the 90-93 wiring diagram, was easy and straightforward.
Q451990
:welcome: to NICO! I'm glad you got it figured out.
