DrewQ45 »
https://forums.nicoclub.com/drewq45-u2328.html
Thu Nov 17, 2005 9:06 am
I've pulled apart my cluster before to replace the Speedo as well as the trip bulbs. Speedo and Odo are separate items removable independent of each other. You can eyeball it and figure it out. Sorry, but if you get someone else's odo and roll the numbers, they will never line up perfectly again. Be careful to keep things sqeakly clean and blow all dust out before putting it back together. Oh, when removing cluster, you will need to remove plastic ignition housing and also loosen steering column bolts to drop column for needed clearance.
Hope you got small hands.... The connecting wire harnesses when installing is a major PITA and if not connected properly, It will scare the hell out of you with many things not working...AC, Heat, Console lights, car not charging etc. You must push on the plugs until you hear them click solidly.
Right now I have a dead moth sitting inside my cluster... not sure how the hell the little bastard got in, but he did and now lays feet up next to the warning lights the past few months. When he was alive, I tried to coax him towards the trip reset stem with lights so I could yank him with a tweezer but he wasnt' game.
..Drew...
