xcrazymike wrote: what do you mean can i confirm it has fuel and spark?
I mean is the fuel pump working, as in can you hear it prime for about 5 seconds when the ignition is in the ON position?
And for spark can you confirm all the spark plugs are firing?
xcrazymike wrote:also, do you really think it may just be the alternator? should i order an alternator with the voltage regulator in it??
You should either have someone who has been in the business for a long time rebuild your current alternator or Buy a New OEM one.
The rebuild is cheaper, but it depends on the person rebuilding it as to how long it will last.
As for aftermarket well you can take your chances there but some do get lucky, It all depends on the Chinese persons day.
