90 Q45 Injector leak
1990Q45'r
Car: 1990 Q45
FYI,Had CEL blinking 45 (injector leak).......great Decided to pull off plenum and then injector tubes to see which one was leaking.I'll be danged none were leaking I then noticed #2 injector (3 years since replaced) was missing the plastic covering at tip of injector ! Only found a portion still attached.Installed new injector and thankfully solved problem.1990Q45'r
Q451990
1990Q45’r wrote:FYI,Had CEL blinking 45 (injector leak).......great Decided to pull off plenum and then injector tubes to see which one was leaking.I'll be danged none were leaking
The code indicating "injector leak" (I believe) is just an indication of running rich. The ECU assumes that the cause is a leaky injector.
Heath
1990Q45'r
Car: 1990 Q45
Yea Heath, I believe the broken plastic end may have disrupted the proper atomization of the fuel out the tip, allowing liquid fuel to be present in intake tube.
