jonseyq45 »
https://forums.nicoclub.com/jonseyq45-u89783.html
Mon Mar 03, 2008 8:34 am
Just bought the Q. During first drive the car would not shift. Found by backing off the throttle slightly if t would shift into next gear. It would also down shift at the slightest grade or load. Talked to a transmission shop, his suggestion check TPS. I have it rotated foward as far as it will go and it is now shifting, not great but shifting. Also takes a long time to go into 4Th and at any incline backs down to third. It pulls hard when in gear, no slippage noticed. It apperas to start in 1st and then almost seems to go into 3rd when accelerating on any thing other than a light pedal. Only once did it seem to go into 2nd than back to first (first shift of the morning)
Things I have done; Adjusted TPS Flushed transmission (not drain and refill) Replaced screen and added suggested Red lube Adjusted kickdown switch at the pedal inside Checked connectors at the rear of the transmission (underneath)
Vehicle: 1990 Q45 Miles: 162,000 Condition: 9/10
No unsual noises, starts and runs great. I have not checked the voltage at the TPS yet. I will do that this evening.
Thanks for any helpSam Jones cell 360-566-7476 if you want to call me
