Attached and below is a picture of the TPS.. Theres 2 screws that hold it onto the Throttle Body, you can only see the top one, the other one is directly below it on its respective side...staats wrote:A generous offer indeed. Now where is this sensor and how do I change it?
My situation is that I no longer have a lift or garage to do my own work, sigh. That's why I'm trying to get a better idea of what it could be.
I have a local dealer that's been reasonably decent, not great. I always like to go in well prepared.
Perhaps the water thing is a coincidence but it does seem like at times it will just start going erratic, even at highway speeds, so that's why I thought it was possibly a connector or both!!!!Thank you
Just in case you missed it.staats wrote:An update from the field.
II see no evidence of water on the transmission dipstick.
Bob
No, there's no significance to it.AZhitman wrote:Bob - Off topic, but does your screen name have anything to do with bikes?
Just an old BMX dad wondering...
Transmission vent??DominickJ30 wrote:Your transmission vent sucked up water when your wife drove it through the puddle.
Every single paper clutch in the transmission is now junk. Time for an overhaul.
Check your fluid level and condition to confirm this.
sounds more like the solenoid pack.staats wrote:Perhaps, but it does seem electronic in nature and when it's not acting up it's just fine.
Do you know where the vent is located, i.e. how high?
Jamesmost,Yes I'm in Northern NJ but I cant find an Elmont NJ. I can find a Belmont Park NJ. Where is this shop????jamesmost wrote:Statts where in NJ r u? if northern i have a friend w/a trans. shop in Elmont by Belmont racetrack(40-60 min drive)t and honest will give a free look. and let u know what is up
elmont is on Long Island Queens Borderline Drom me an e-mail i will give u info he rebuilt a killer trans for mestaats wrote:
Bob
I just got the harness off of both points on the TPS and yes there were tiny amounts of corrosion so I'm cleaning those up to see if that's my problem.elwesso wrote:Ok so now onto adjustment of the TPS.. Attached is a picture of how to do this, via the FSM...
Basically all you do is once you install the new TPS, you adjust it based on this chart... With the accelerator fully released (IE the butterfly is completely closed), you probe the 2 listed things on the TPS connector (there are 2 connectors, one one for the Throttle switch and the throttle position sensor, the throttle switch connector is on the sensor body, the sensor switch is the one on the little wire connected to the sensor).......
Anywho, probe the 2 listed prongs on the TPS harness connector and adjust it so that your VOM reads approx. .7 ohms...... you put your VOM on the lowest OHM reading..... on mine for instance it is 200ohm.....
Let me know if theres anything i havent made clear.
Are you asking what a trans vent is or are you implying that this trans doesnt have one?jamesmost wrote:Transmission vent??
how is a trans vent going to take in H20 where is it ?? is it a pressure release valve??DominickJ30 wrote:
