DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue Mar 16, 2004 8:52 am
If all your connections are fine, and after jiggling all the harness connectors, then the very next thing to do, aside from hooking it up to a Consult, would be a compression test. If your timing is off, I'm guessing you're not feeling a miss, but rather the engine fighting against itself...maybe the spark is happening way too early. If the compression comes in good, then my next guess would be that the CAS isn't installed properly.
