Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sun Feb 04, 2007 4:31 pm
I not sure people understand the concept of camber, caster, abd toe curves.
How much and what direction the numbers change as the body rolls and dives or lifts during various manuevers.
They get all fixated on static misalignment numbers even with correct loads [in seat] at alignment.
Use a protractor a length of twine and a weight to see the gigantic amount of camber GAIN as you turn the wheel.
Caster changes also as does toe from the load stresses things a alignment cannot show you.
