Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Sep 09, 2004 3:33 am
"It keeps the RPMs up when the car's cold so it warms up faster."
No, that is the PRIMARY job of the throttle body mounted wax/spring [coolant controlled] thermo ---- throttle valve cracker opener [warm up idle cam]..........why the two coolant line go to throttle body.The IAC is limited in the amount of air it can flow.
The AAC/IAC along with variable ecu ignition advance attempts to keep HOT idle speed at 650-675 rpm under the varying load of alternator, power steering, AC compressor. Also at cruise it acts like a sudden throttle close dampener to progressively let the rpms fall [in steps] when you suddenly let off throttle.
You set the IAC screw by turning it all the way in, then back out 2.5 to 3 turns............if the idle is not at the correct HOT rpm either the IAC is dirty inside or the throttle body is dirty or something else is misadjusted.
Ideally one would use a Consult to see that the ecu is pulsing the IAC solenoid at 10% duty cycle [no lights, no AC on] at HOT idle.
All about dynamic range: an IAC with 10% allows a significant range of upward additional air to compensate for loads [AC on say 25-30%] [all electrical drain worst case adds another 10%] turning the steering wheel fully adds 10%. At 70-80 mph the IAC reads like 60%-80%........setting a floor on engine rpm.
80% IAC pulse duty should raise the unloaded idle to like 1100-1300 rpms.....what happens during a power balance test.
