maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Mon Jun 30, 2008 7:04 pm
Then you are at junkyard mercy. You must at a minimum have a new fuel pump, new fuel filter and a new O ring. You can use a used fuel pump, but you are on borrowed time and may take out your FPCU also if you haven't already.
All this assumes no corrosion nor contamination fo the fuel lines and tank.
So I would say park it until your can repair it right or face further expense. The good news is you can read the fuel pump thread in IOM and know everything the next time.
Modified by maxnix at 9:07 AM 7/1/2008
