Darrel wrote:Also, I don't think the cam guides have been replaced. With 110K miles, how big a risk are they?
A huge risk! Mine went at 120K, but I have personally seen failures at 77K, and we have documented failures lower than that on the board. I would say the average is around 120K. You're definately driving on borrowed time.
I actually replaced all of my injectors back in 1998 after having one fail... replacing it, and then having another failure in a few weeks. Pulling the plenum is a bear, and I didn't want to do it once a month. Looking back on it I wonder if an injector flush would have cured me. I didn't ohm them... just went to the dealer and got a power balance test. They told me which one was bad and I replaced it.
I would absolutely do the ohm testing. If they check out OK I would try a rail flush first. Essentially it's a pressuirized canister (fed by compressed air) that forces a solvent through the injectors. The fuel lines are looped back to the tank and the car is run on the cleaner until it's used.
Good luck!
Heath
