evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Jun 26, 2010 10:14 pm
what I do it:
take the 2 bolts out of the tensioner so it's only held on with the pivot stud and the tensioner arm is compressed wiht the 6x1.0 bolt
with the belt aligned I pivot the tensioer into the belt and put in the ther 2 bolts, I push it againse the belt and lock it down and remove the 6x1.0
I then use a spacer to put the crank bolt in without bottoming out, and give the engien a full rotation
I then put the 6x1.0 back into the tensioner and do nto tighten it all the way
I then loosen the tensioer mounting bolts and push it firmly against the belt, then I pull the 6x1.0 and I'm done
that help?
