Z31toZ32 »
https://forums.nicoclub.com/z31toz32-u97552.html
Wed Feb 09, 2011 7:56 pm
greetings and welcome here to nico.
1.) the lifter tick is very common with the higher mileage zs. it really isn't a big deal, but is annoying. you could try a few bandaide fixes such as running a thicker oil, seafoam, or a quart of ATF in the oil for a few miles, but they dont get to the root of the problem which would require taking them apart and cleaning them. there is a writeup somewhere.
2.) the oil pressure seems a bit on the high side, but the oil pressure sending unit also isn't the most reliable in its age (although usually it reads lower). ballpark is 10-15 idle, 30 in town, 45 on the highway, and 60+ when cold. how thick of oil is he running?
3.) cant really tell what it is worth given your description. some things to look for are a recent timing belt (cost $1200 w/ labor), and fuel injectors replaced for the 90-93 models (another $1200). the short throw shifter wont add any value and a new clutch will add next to no value (but decent piece of mind) post up some pictures, and mileage would help too.
