datdude407 »
https://forums.nicoclub.com/datdude407-u165301.html
Mon Aug 16, 2010 10:55 am
Six weeks ago I started the plenum pull to change the injectors.I put a new fuel rail in with 6 new injectors. I have everything back together and the car wont sart. Everything is hooked up. Im getting fuel, idk if im getting spark. I ran ECU test & got 34 & 42. Now I changed the the fuel temp sensor from old fuel rail & i did a knock sensor bypass and i am still getting the same codes and is still not cranking up. Please help. I havent even had a chance to drive the car yet, brought it in may with 2 bad injectors and had it parked the rest of the time
