Had the surging idle problem so I thought I would try Robo's Idle Air Adjuster & Air Regulator cleaning
http://s95014253.onlinehome.us/63104/157335.html
I disconnected the hose in between the IAA and the Air Regulator to do the cleaning, but then the car wouldn't start. I had someone try to start the car while I plugged up the oppenings to the IAA and Regulator, but the car still would't start (always started prior to this and has a brand new battery). At this point I decided not to do the cleaning with the WD-40 and instead reconnected the hose between the IAA and Regulator, but the car still won't start. It cranks, but even with a battery boost, it will not start up. I tried disconnecting the battery for an hour to reset the ECU, but no change. Anyone have this problem after tyring this procedure, or have any ideas?
Thank you.
