90 ka24e running ruff
Cooler_08
Car: 90' Nissan 240sx
I got a 90 240sx with a ka24e and the guy i bought from hacked the emissions. Now when i start it it acts like it is misfiring but i have changed the plugs, wires, cap, and rotor button and changed the maf sensor but no luck. i did see that the egr pipe that is supposed to go into the header was cut off and just pinched. so could that be the problem. please help really need it
Thannk you for your time
singleslammer251
Car: 1989 Nissan 240sx SE Stock rebuilt KA24E mild N/A build
sounds most likely like the egr pipe u mentioned. your ecu is going crazy cuz there is more air going in than it is measuring thru your maf. try to get someone to weld it shut.
