Hiya, I'm new to the forum here, which I just found while researching this problem. I've found a few posts regarding the injector o-rings on the KA24E and was wondering if anyone could help me out here.I just got a '90 240 back in July and have been fixing it up as I go. A couple months ago I noticed a gas smell and found the injectors to be leaking from the rail, so I got a set an injector seal kit from Advance (part number 158-0372). The upper and lower seals are fine, but the o-ring going into the rail is too small. It fit the injector snugly, but offered no resistance going into the rail, so it leaked like crazy.Next step, hit Google and found this forum. I sent my injectors to Deatschwerks to be serviced. When they came back I lubed the o-rings and tried again. These were closer than the Advance ones, but still went into the rail a little more firmly but I still had seepage on a couple. After several attempts to re-seat them I had similar results, I could get a few to seal but never all of them. Next I tried Autozone, who gave me GP Sorensen o-rings(part number 800-9209). These were loose on the injectors, but plopped in the rail more snuggly. I still couldn't get all of them to seal again though. After several attempts I contacted a local Nissan dealer who gave me the oem part number. For anyone who may need them the o-ring is part number 16618-78A00, the upper seal is 16636-U5000, and the lower is 16635-78A00. He told me they could order them and have them in four days or that Advance could cross refernce the number. I hit Advance and got the GP Sorensen part number 800-9330, which is supposed to be the same as the oem size. They fit the injector snugly and plop into the rail snugly, but still seep when the engine is running. They don't leak when the engine is shut off and pressure is standing on the system though. What I'm wondering is if anyone has tried the oem part from Nissan(16618-78A00) and if I should spend more money and order them and try them, or is it possible I have another problem? I've inspected the rail and it looks fine, I'm lubricating the o-rings and put them in evenly, they pop in and I can rotate them injector in the rail. Is it possible for the fuel pressure regulator to be bad and allow too much pressure on the rail when the engine is running? Or could it be a vacuum problem? Or do I just need to keep buying o-rings? Thanks for any info, and hopefully these part numbers will save someone out there some cash and wasted time
