4gotn1 »
https://forums.nicoclub.com/4gotn1-u25219.html
Sat Jun 11, 2005 2:16 pm
heres everything thats done to my 90 coupe. it is hella fun to drive. maybe you could get a few ideas from what i have done.
obx header, custom intake, kyo exhaust 3in, 2.5 in test pipe, magnecore wires, msd blaster 2 coil, asp underdrive pulley, removed emmisions (completely), obx adj fuel pressure regulator, 300zx fuel filter, walboro fuel pump, 16in electric fan conversion, removed secondary butterfly valves, ported intake, manifold, port and polished head, 3 angle, valve job, decked head, nismo motor mounts, nismo transmission mount, myth concepts tuned ecu, removed ac (complete), battery relocated to trunk, ground kit, exedy stage 1 clutch, obx short shifter, eibach sportlines, kyb gr2s, rear subframe spacers, energy suspension, bushing set, front and rear strut tower bars, 17x7.5 white 6 spoke rims, 235/45zr17 michelin piolt sports, 180sx jspec limited slip differental,
and its gutted, has a d1 front end on it, and some guages on the inside. its pretty fun little car. im using moble 1 synth in the engine transmission and diff and it loves it. made a noticiable difference over the 14yr old **** in there.
