90 ka24 hatch clutch install
drifter sx
Car: the usual
how do i install a new clutch in my 90 hatch KA24?? never done this before and dont wanna mess it up. any tips?
Nismo1182
Car: Z06
I did mine about 1 month ago. Ive never done a RWD transmission before just on a few Hondas so this was a peice of cake compared to those. This is what I did:
-Jacked up the whole car and put it on jackstands.-drain the transmission. The drain plug is right on the bottom and has a adapter style hole.-disconnected the driveshaft at the diff and then unbolted the center coupling.-slide out the driveshaft.-there should be 8 or 10 14mm bolts holding the transmission on. -once you remove those make sure you have something to support the transmission underneath, now remove the transmission mount. I think its 17mm?-pull the transmission out.
6 12mm bolts hold the pressure plate on.
I would be better if you have someone whos done other rwd cars before help you.
drifter sx
Car: the usual
thanks man for the tips, at least i have a place to start now.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
http://www.240sx.org/links/installs/flywheel/
This has some decent pics to help you.
95_240sx
Car: My baby (car)
As far as the pressure plate bolts, does anyone know if they need to be any special type of bolt? Also, anyone know what length they need to be?
Rick
Nismo1182
Car: Z06
95_240sx wrote:As far as the pressure plate bolts, does anyone know if they need to be any special type of bolt? Also, anyone know what length they need to be?
Rick
did you lose them?
95_240sx
Car: My baby (car)
No, I didnt lose them. But the donor engine I got for my engine buildup, was originally equipped with a flexplate for an auto trans, so I never had pressure plate bolts to even lose.
Rick
Touchdown038
Car: Computers, cars, sports
They looked like normal bolts to me when I did it a couple months ago.
