90 d21 runs BAD
FreQ13
Car: 1990 Nissan Hardbody
so my 90 D21 startes spitting and sputtering today on ym way home and a little while later I check my plugs and wires to see if something came loose (#3 plug was loose) and when I went to start it back up its still running like poo and doesnt want to stay running even with the pedal to the floor I havent checked spark at the plugs or anything yet because it started to get dark on me
any other ideas? distributor or coil maybe? something fuel related? clogged cat?
Im at a loss ATM
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
I'm in the same situation right now...I went through a big *** puddle and now I am having more problems then i can shake a stick at.
A big help to get me where i have so far was the Haynes book for our trucks, not the greatest but it gives you some helpful bathroom reading!
FreQ13
real meesed up thing is I didnt run thru a puddle
it hasnt rained here in like 2 weeks it just all of a sudden happened
FreQ13
so I changed out the dizzy cap and thats not it it still runs like dogpoo
any other ideas?
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Did you change the rotor when you did the cap?
How about plugs and wires?
If those are things that haven't been done in a long time anyways, you might as well do t hem.
OEM parts are best in this case.
FreQ13
actually I changed the plugs and wires out about a month or 2 ago and I just replaced the cap today gonna pull the plugs and recheck them though
FreQ13
ok Im retarded!!!
I was out of gas... but in my defense my gas gauge doesnt work and I did more driving and running around than normal and ddnt realize it
I pulled the fitting off the fuel rail and cranked it over a bunch and there wasnt anything coming out so I thought either I was out of gas or my fuel pump went out and I tried the cheapest fix 1st and lo and behold
NO GAS!
but a couple gallons in and she fired right back up
